More RAAL systems on the way...
0 Members and 1 Guest are viewing this topic. Read 4270 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« on: 23 Feb 2010, 09:31 pm »
We just finished a nearfield monitor and a state-of-the-art 3-way and matching center channel are in progress.  :thumb:
sunandmoon
Re: More RAAL systems on the way...
« Reply #1 on: 24 Feb 2010, 02:02 am »
...I am curious about the mid in the 3-way - wondering what you selected...
standub
« Reply #2 on: 24 Feb 2010, 05:50 am »
Me too...
cstory
  • Seaching for clues
« Reply #3 on: 24 Feb 2010, 02:21 pm »
If I were to design a 3 way based on what I've seen Rick mention, I would guess he might use the 7" Scan Speak Illuminator aluminium woofer that is being used in the Verita's, and add a 10" Scan-Speak Revelator Aluminum woofer to fill in the bottom.  :eyebrows:
But then again, I could be totally wrong.  :D
Chuck
Rick Craig
  • Selah Audio
« Reply #4 on: 24 Feb 2010, 06:38 pm »
Accuton 2" ceramic dome.
Rick Craig
  • Selah Audio
« Reply #5 on: 24 Feb 2010, 07:06 pm »
Chuck
This is a monitor but your combination is also a good one.
standub
« Reply #6 on: 11 Mar 2010, 12:29 am »
Rick,
Any plans on using the Accuton C96?  Seems with the rather high sensitivity it's begging to be put in a "home theater" aimed speaker.
cujobob
« Reply #7 on: 11 Mar 2010, 01:12 am »
The cost of the drivers alone is just massive.
Rick Craig
  • Selah Audio
« Reply #8 on: 11 Mar 2010, 01:31 am »
Rick,
Sure it could be used but only in certain applications. If you're thinking of it being a woofer the bass extension will be very limited.
Rick Craig
  • Selah Audio
« Reply #9 on: 11 Mar 2010, 02:25 am »
Cabinets are now finished.  :thumb:
jtwrace
    • TIPP YouTube Channel
« Reply #10 on: 12 Mar 2010, 12:27 pm »
Which RAAL are you using?
Rick Craig
  • Selah Audio
« Reply #11 on: 12 Mar 2010, 02:46 pm »
The 70-10D. It has the best performance of any ribbon I've tested in the top two octaves and is perfect for dome mids.
