Friend gave me a scope
0 Members and 1 Guest are viewing this topic. Read 1859 times.
sts9fan
« on: 23 Feb 2010, 02:17 pm »
Its a philips PM3207.  Is it usable for audio?  I have no idea how to use it.
Dan Banquer
Re: Friend gave me a scope
« Reply #1 on: 23 Feb 2010, 03:12 pm »
Need some lessons?
Dan Banquer
Bill Baker
    • Musica Bella Audio
« Reply #2 on: 23 Feb 2010, 03:22 pm »
If you do a google search, you will come up with a lot of very useful information on using a scope for audio. What you have will work just fine but make sure you obtain some knowledge before sticking probes into your electronics.
First thing you will want to do is calibrate it.
Once you master it, it will become your best friend as you venture into circuit design.
TomS
« Reply #3 on: 23 Feb 2010, 03:39 pm »
+1 on what Bill said about poking around.  HV tube stuff can definitely be lethal without the right precautions, probes, etc.
Now you need to look for a nice cheapo function generator  :wink:  I got an old Wavetek 130 for about $30 on eBay.  Works great and is built like a tank.  Lots of good similar ones around.  Of course you can generate signals from CD or PC sound gen but it's a pain for me on the bench.  I do it the old way, get lots of output too.
sts9fan
« Reply #4 on: 23 Feb 2010, 03:46 pm »
Dan I will take you up on that for sure.
Thanks for the info guys.  I am pretty comfortable with instrumentation so this should be fun.
Kris
Bill Baker
« Reply #5 on: 23 Feb 2010, 03:46 pm »
 Another thing to look out for is the "bug". The scope is only the first step, then a function generator, then bench top meters............ next thing you know, you'll end up with benches full of test gear :duh:
TomS
« Reply #6 on: 23 Feb 2010, 03:58 pm »
And then mo' betta' kicks in  :green:
mgalusha
« Reply #7 on: 23 Feb 2010, 06:18 pm »
Which then turns into an addiction.. I had to remodel my bench to accommodate the ever growing collection..
Bill A
« Reply #8 on: 23 Feb 2010, 06:48 pm »
Here's a service manual for it.  The site is a little quirky, but can be worked through without much trouble.  It is a multipart file, so download all parts before decompressing.
http://www.eserviceinfo.com/downloadsm/27672/PHILLIPS_PM3207.html
Hopefully it will also have a bit of a user guide, too.
Bill
sts9fan
« Reply #9 on: 23 Feb 2010, 07:40 pm »
Thanks Bill!
pjchappy
« Reply #10 on: 23 Feb 2010, 07:45 pm »
After reading the subject line and nothing else, I just have to ask. . . is your friend a doctor?  Which end?
 :rotflmao:
(sorry. . .couldn't resist)
Paul
