Are these monster RCA Radiotron tubes useful?
0 Members and 1 Guest are viewing this topic. Read 8974 times.
WGH
« on: 22 Feb 2010, 10:15 pm »
These two tubes have been in an attic for 20 years and look new though nobody in Tucson has a big enough tube tester to check them out, can anyone use them?
There is only one of each: a Radiotron 869B and a Radiotron 4-250A 5D22
Wayne
jules
Re: Are these monster RCA Radiotron tubes useful?
« Reply #1 on: 22 Feb 2010, 10:42 pm »
Spectacular tubes! Thanks for posting the pics.
250W mono push pull amp perhaps?
http://www.marchandelec.com/bigtubeamp.html
the 869 seems to be a half wave mercury rectifier.
http://www.scottbecker.net/tube/sheets/049/8/869B.pdf
jules
JakeJ
« Reply #2 on: 22 Feb 2010, 10:45 pm »
According to the Duncan Amps Tube Datasheet Locator the 869B is a mercury vapor half-wave rectifier (careful not to break it!) that can handle 10 - 20K inverse volts, will pass up to 20 amps, and emits x-rays when pushed hard.  :o The 5D22 is a power tetrode that is capable of outputting 750 Watts with 3000 volts DC applied to the plate.  :o :o
Link 1 and
Link 2
Ooops...Jules beat me to the punc!
jules
« Reply #3 on: 22 Feb 2010, 11:05 pm »
Beautiful as it is, the 869 might not make such a good bedside lamp after all  :lol:
jules
JakeJ
« Reply #4 on: 22 Feb 2010, 11:37 pm »
jules
:rotflmao:
WGH
« Reply #5 on: 23 Feb 2010, 12:46 am »
Thanks guys. The tubes belong to a friend who wants to sell them. Any offers?
The 869 rectifier would be the ultimate Cornet2 tweak. :drool:
tubesforever are you listening?   :lol:
Wayne
Ericus Rex
« Reply #6 on: 23 Feb 2010, 01:23 pm »
I think the 4-250a is used in HAM radios.  Maybe posting on a HAM board would be more beneficial?
Unison845
« Reply #7 on: 24 Sep 2010, 03:21 pm »
I did build a SET using Eimac 250 which has same physical look , long long time ago.
djn
« Reply #8 on: 30 Sep 2010, 06:07 pm »
Hi Unison, can you tell us more about your 250 amp?
Unison845
« Reply #9 on: 1 Oct 2010, 01:08 pm »
What you would like to know about it?
JakeJ
« Reply #10 on: 1 Oct 2010, 04:06 pm »
OK I'll go first!
1.  All the iron looks to be from on mfr, who (or whom)?
2.  What are the three silvery cans between the OPT and power xfrmrs that look like funny shaped cans of spam?
3.  What are the two smaller dealies that look suspiciously like trannies but I think are chokes sitting there right behind the dual rectifier tubes?
4.  What is the tube compliment?
5.  If it isn't IP property, schematic? Preferably with values, please!
Oh and nice cabinetry too!  Mahogany top and Tiger Maple sides?
Thank you!
djn
« Reply #11 on: 1 Oct 2010, 04:23 pm »
Thanks Jake.
To add to that:
1 what is the B+
2 what is the driver complement
3 is the PS choke input or Cap input
4 are you using interstage or cap coupled
5 How does it sound with those tubes?
Unison845
« Reply #12 on: 1 Oct 2010, 10:22 pm »
     Tamura from Japan, along with Tango, they are the best and only what I would used now, I have wasted lot of times and $ trying others. Japanese transformers are true to their spec, can't beat them sound wise.
     They are oil caps 1500V 15uF.
     Tamura chokes, 10H 200ma each. I used double choke. There are 4 rectifiers, the big ones are for power tubes, the small one are for input/driver.
     12AY7 input KT66 driver.
     This was built long time ago, around 95, schematic was never drawn, it was in my head back then.
   Top is Aluminum anodized in gold, wood chassis is Birdeye Maple.
1 what is the B+
     920V
   15uF/1500V cap input
   Interstages are under the chassis, the rest are all Tamuras.
   I would used this amp for the mid/hi in an active system. I prefer 845 from lower to mid/lo. From mid up they are very clear and detailed with great resolution, and not a hint of edginess, even when using them on horn system which what I used now to drive the Altec horns.
