dumb question?
0 Members and 1 Guest are viewing this topic. Read 1887 times.
drphoto
dumb question?
« on: 21 Feb 2010, 03:40 am »
Ok, I ordered an H frame kit from Chris Swiger and he sent me a W frame. I thought he was gonna swap me, but so far no word on it.
Anyway, assuming I'm stuck w/ the "W", how do you screw in the drivers? Looks like an really tight fit in there. Besides the fact, I wanted the option to upgrade to the V1 at some point, which was why I wanted the "H" in the first place.... was ease of driver placement Do you need some sort of "L" shaped phillips screwdriver?
« Last Edit: 21 Feb 2010, 09:02 pm by drphoto »
corndog71
  • Some people call me Rob.
Re: dumb question?
« Reply #1 on: 21 Feb 2010, 05:48 am »
If you're interested in selling it let me know.
drphoto
Re: dumb question?
« Reply #2 on: 22 Feb 2010, 08:21 pm »
Anyone? Do you install the drivers and then put on a removable lid? Prepaint all the parts before assembly, then glue together w/ the drivers in place? Call me stupid (been done before!) but I just don't see how you can access the top screws, once the thing is assembled.
srb
Re: dumb question?
« Reply #3 on: 22 Feb 2010, 08:24 pm »
How much access room is there?  There are a number of 'L' offset screwdrivers available, as well as some ratcheting models, although they usually require a bit more clearance room than the fixed models.
http://www.amazon.com/Wiha-Phillips-Offset-Screwdriver-Handle/dp/B000T9UEDU/ref=sr_1_1?ie=UTF8&s=automotive&qid=1266870308&sr=8-1
Danny Richie
Re: dumb question?
« Reply #4 on: 22 Feb 2010, 08:54 pm »
I put a small Allen headed bolt through the top two holes from the back side and held a nut (from the front side) with a pair of needle nose pliers with a curved tip.
drphoto
Re: dumb question?
« Reply #5 on: 22 Feb 2010, 09:51 pm »
Thanks, I may just try to do an H myself. Should be able to cut the parts w/ a quality circular saw and rip guide. Plus I know from my experience w/ my flat baffles, the driver hole doesn't have to be super precise as the large flange covers a lot of sins.
Corndog, I'll keep you posted.  If I make my own H, I'll make you a good deal on the W. It is cut w/ very high precision......just not what I wanted.
Is there any SONIC advantage to the W over the H?
