Should I put a bybee in the DAC or cable to dac or speakers
0 Members and 1 Guest are viewing this topic. Read 1214 times.
Chris_B
I am wondering if my money is better spent having by DAC modified with a bybee filter or should I go with the digital cable from Bolder/Cryo leading to the DAC?  The other option is the adapter between the speaker terminals and speaker wire that has a bybee on the positive terminal.  I have read that a bybee filter should go close to the end of the signal chain, so the speaker option would be best.  Another person wrote about having a bybee in their DAC and didn't hear much improvement when trying the speaker bybee-terminal adapter.
If you have any experience with these options, please let me know what you think.
Marbles
« Reply #1 on: 29 Jan 2004, 12:55 am »
What DAC do you have?
Chris_B
« Reply #2 on: 29 Jan 2004, 01:08 am »
P-3A that will soon have the Dan Wright level 2 mods.
Marbles
« Reply #3 on: 29 Jan 2004, 01:26 am »
I would not get a bybee that you could not easily remove for this DAC, so for me it would be the inline from Bolder.
cryotweaks
  • Funny name. Serious audio.
    • TweekGeek.com
« Reply #4 on: 29 Jan 2004, 01:42 am »
I think Modwright would agree.  Bybees on the speakers are more dramatic of a benefit.  Buy them raw and solder them in yourself, or buy them in a more portable configuration.
Cheers.
