0 Members and 1 Guest are viewing this topic. Read 11006 times.
The general idea for theater is to have the three front speakers sound as homogonized as possible. This means using the same brand speaker and same amplification, at least for L-Center-R. While I'm sure the center would sound great with this amp you may notice differences in timbre between it and the L & R. Why not get three of these amps?As for reliability, I've never owned an ASL amp but I have owned two of their pre/headphone amps and have never had a problem with either unit. YMMV
I was not aware that these were still being made. I have a pair of AV-8's which are an 8 watt predecessor to the AV-25. They sound wonderful an I have had no problems with them. I owned them for years. I have not heard the AV-25 but have read reviews that were favorable.
The ASL stuff is made to a price point, of course. If you open one up, you'll find cheap flimsy PC boards and military surplus caps and such but, again, my experience is that it's reliable and decent sounding.Best of luck!
Auidioadvisor.com sells them. You wont find them in the regular electronics section. You have to do a search on their website. They may have some customer reviews to look at.......
