Difference between the 'C' series and the Pro series
0 Members and 1 Guest are viewing this topic. Read 1704 times.
canucks0
Can anyone tell me what the difference is between a pair of 7B SST2 'C' series and the 7B SST2 Pro series? I cannot find it on the website. Thanks in advance. Dave.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Difference between the 'C' series and the Pro series
« Reply #1 on: 17 Feb 2010, 12:37 am »
The Pro is available in Black 19 inch rackmount style only and has volume controls in the circuit path to turn the gain down if required.
http://bryston.com/4bsstpro_m.html
james
canucks0
« Reply #2 on: 23 Feb 2010, 10:43 pm »
James, so outside of the faceplate and handles as well as the gain control, the 7B SST2 'C' series and the 7B SST2 Pro series are identical in every way, cosmetically and electronically?
ian.ameline
« Reply #3 on: 23 Feb 2010, 11:04 pm »
Electronically they are identical except for 1 additional passive component -- the variable resistor for gain control on the PRO models. (this can be seen on the schematics published on the Bryston website.
Cosmetically it is purely a matter of taste -- some (myself included) like the pro look. Others like the C series. I've seen them side by side, and they both look great.
-- Ian.
