sandbox sub
0 Members and 1 Guest are viewing this topic. Read 4623 times.
drmike
sandbox sub
« on: 15 Feb 2010, 08:37 pm »
where can i see plans on how this is put together?
thanks,
drmike
Danny Richie
Re: sandbox sub
« Reply #1 on: 15 Feb 2010, 10:09 pm »
drmike
Re: sandbox sub
« Reply #2 on: 16 Feb 2010, 09:25 pm »
thanks danny. does this still use the same driver? can this be used firing downward if placed on short legs?
thank you,
drmike
Danny Richie
Re: sandbox sub
« Reply #3 on: 16 Feb 2010, 09:41 pm »
Sure.
SW-12-04's are in stock and ready to ship.
You can down fire it if you like as well. With this box design, it would put the amp on the top of the box though.
dvenardos
Re: sandbox sub
« Reply #4 on: 16 Feb 2010, 11:46 pm »
This is my favorite downfiring sandbox:
http://www.audiocircle.com/index.php?topic=63528.0
thank you,
drmike
m-fine
Re: sandbox sub
« Reply #5 on: 17 Feb 2010, 01:23 am »
That is one heck of a nice DIY sub!!!!!
madpoet
Re: sandbox sub
« Reply #6 on: 17 Feb 2010, 10:40 pm »
Go for it... the Sandbox sub is really nice.  I love my dual, albeit front firing.  The amp is mounted in a seperate box.
Plaid Frog
Re: sandbox sub
« Reply #7 on: 20 Feb 2010, 06:18 pm »
What do you use your dual Sand Box sub for?  Music vs HT?  I am considering a dual Sandbox setup for HT use and want to know if they will have the output & performance for that application.
dvenardos
Re: sandbox sub
« Reply #8 on: 20 Feb 2010, 10:29 pm »
If you go with a dual and make the drivers opposing, you really don't need a sandbox as the resonance from the woofers will cancel each other out.
madpoet
Re: sandbox sub
« Reply #9 on: 21 Feb 2010, 01:58 pm »
Mine's for HT.  Servo subs are a different beast... you need to get used to them.  They are incredibly clean, but I don't necessarily feel the oomph to the gut I used to get.  Thye sound fantastic though :)
Danny Richie
Re: sandbox sub
« Reply #10 on: 21 Feb 2010, 05:53 pm »
Regardless if they are on the same side of a box or opposite sides of the box, they still put the same pressures on the enclosure. Plenty of bracing is always recommended and the sand box is always a plus.
dvenardos
Re: sandbox sub
« Reply #11 on: 23 Feb 2010, 04:16 am »
Thanks for the correction.
