DAC/Tube headphone amp- Under $200? Is this for real?
0 Members and 1 Guest are viewing this topic. Read 11795 times.
dB Cooper
Anybody know anything about this product? A DAC/ tube headphone amp for $169????!?!?!?  :o
Here's the link to the page the image is from:
http://head-direct.com/product_detail.php?p=74#
dB Cooper
angelo
Re: DAC/Tube headphone amp- Under $200? Is this for real?
« Reply #2 on: 16 Feb 2010, 03:55 am »
Yes, it is for real :) I ordered one from that site and it arrived after 1 week. I'm using it w/ the Denon D5000. I'm very satisfied w/ the performance and you can't beat the price. The build quality is very solid and the sound is much better than my old zhaolu dac w/ discrete headphone amp. I haven't changed the stock tube but you can buy better tubes in ebay for $30.
funkmonkey
« Reply #3 on: 16 Feb 2010, 04:39 am »
Same guys that make the excellent Yuin earbuds... I think.  Head direct is trustworthy and easy to do business with as well.
dB Cooper
« Reply #4 on: 16 Feb 2010, 06:32 pm »
Thanks for the feedback (pun intended). Looked like a pretty sweet deal. Bordering on too-good-to-be-true.
atothex
« Reply #5 on: 18 Feb 2010, 12:07 am »
It's a hybrid, not a real tube.
If you're really into dirt cheap, you can just use a soundcard with one of these stupid looking things:
http://cgi.ebay.com/Valve-Class-A-Tube-Headphone-Amplifier-pre-Bravo-V2_W0QQitemZ260541961646QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca982d5ae
doctorcilantro
« Reply #6 on: 28 Feb 2010, 04:10 am »
The Maverick D1 is $200....you can swap opamps and it has a tube pre output w/ volume bypass.
mbakes
« Reply #7 on: 4 Mar 2010, 01:04 am »
Fang (Head-Direct) is a great guy and has some interesting products.  Anyone in the NY area, there is a meet in Bayside and he will be there with a lot of the stuff he sells.
ltr317
« Reply #8 on: 4 Mar 2010, 01:39 am »
When and where?  Thanks.
saisunil
  • Speakers....What Speakers ?
« Reply #10 on: 12 Mar 2010, 08:34 pm »
I see a few Raver's on that list... 8)
Gopher
« Reply #11 on: 25 Mar 2010, 03:01 am »
I'm listening to this DAC/amp with a pair of Audio Technica AD900s as I type this, and its a pretty competent cheapie combination.
The DAC does leave something to be desired, but I'm listening with the single ended RCAs from a Nighthawk phonostage and its doing well.
nunhgrader
« Reply #12 on: 17 Jun 2010, 02:51 pm »
Pretty cool!
silver_strings
« Reply #13 on: 7 Jul 2010, 11:42 am »
I dont think this actuly qualifies as a tube amp it looks like its a solid state amp and a tube buffer was added to color the sound. Check out the tadac if you want a real tube dac/amp it uses the tube for headphones amplification and has one of the best dac's out there, it's not cheap though
