0 Members and 1 Guest are viewing this topic. Read 2100 times.
I will ask engineering but at home on my Torus CS15 AVR unit (which shows the amperage draw) when I turn on the BP26 it draws 1/10th of an amp. The SP2 /SPV-1 draws 2/10ths of an amp.james
James,Are those for a 240V or 120V system?HsvHeelFan
ok. thanks, James. so the consumption depends on the amp that is used??? something like "the bigger the amp - the higher the pre's consumption" ??? i don't really think that is the case...but who knows?! let's see what engineering have to say.al.
No the amps size will not affect the current draw from the preamp.james
