Omega Mikro Ebony Jumpers or Speaker Cables for Monoblocks, 39" set of four
0 Members and 1 Guest are viewing this topic. Read 1308 times.
mikeg1
Original owner and about two months. Went to single wire speakers and no longer need these cables.  39" tip to tip,.  They have spade connectors.  Can be used as speaker cables for monoblocks. Asking $218 (was $436 new).
Ebony jumper sets use the same mono-silver on copper ribbon and fine insulated copper mesh we use in our top-of-the-line Ebony Planar Speaker Cables. You’ll get better sound using a single set of Omega Mikro Speaker Cables and a set of Ebony Jumper Sets rather than bi wiring. This is so because Omega Mikro Speaker Cables and Ebony jumper Sets have very little smear (because of their low dielectric absorption and low differential time delay) and thus don’t benefit like other speaker cable products do when reducing their frequency spectrum load. You’ll be amazed at the improvement you’ll hear when replacing your bi-wires with a single set of Omega Mikro Speaker Cables and Ebony jumpers.
« Last Edit: 23 Feb 2010, 02:21 pm by mikeg1 »
mikeg1
bump.
