0 Members and 1 Guest are viewing this topic. Read 3924 times.
Now that I have seen the inside of the 40's, I have to believe that there is potential for improvement. Outside of the TRT caps, it looks like most of the parts are fairly inexpensive off the shelf products.Has anybody "upgraded" the crossover components and tried "better" parts?
Now that I have seen the inside of the 40's, I have to believe that there is potential for improvement. Outside of the TRT caps, it looks like most of the parts are fairly inexpensive off the shelf products.Has anybody "upgraded" the crossover components and tried "better" parts? What about changing the insulation for other material? Poly batting, lamb's wool, etc...Does better parts equate to better sound?I realize the 40's are very good speakers already, just wondering if there is a fairly inexpensive way to make them even better.GW
Just exchanged some e-mails with Brian and he said it would be fine to go ahead try lamb's wool behind the panels. He did day that it wouldn't work for the bass b/c it doesn't do well below 100Hz.I am going to order some wool from Madisound.com and see what happens.GW
