X-bass on/off on sp 1.7
0 Members and 1 Guest are viewing this topic. Read 1185 times.
misko
« on: 13 Feb 2010, 09:55 am »
could somebody tell me how to engage/disengage?
Going over the forum for one hour and just cant find it.
thanks
mike
Levi
Re: X-bass on/off on sp 1.7
« Reply #1 on: 13 Feb 2010, 12:44 pm »
Hi Mike,
My firmware is 44a on my SP1.7.  Engaging the X-bass, simply go to the setup menu.  Then go to OS and adjust the level of the extra bass.  I don't use X-bass so my level is at 0.0db.
Manual for the SP1.7 is available in Bryston's website.  I hope this helps.
misko
« Reply #2 on: 13 Feb 2010, 03:12 pm »
thanks levi
my settings is 0.0db too,but i just wanted to be sure it isnt on.
So at zero db it should be off?
I remember i have seen  somewhere in the menu option  xbass on/off..,or not? :scratch:
mike
misko
« Reply #3 on: 13 Feb 2010, 03:14 pm »
...Yeah youre right im going to the manual :duh:
