Back Side of the HT3
0 Members and 1 Guest are viewing this topic. Read 1981 times.
Vulcan00
  • SEM Micrograph of Dendritic Structure
« on: 11 Feb 2010, 09:43 pm »
I can't remember If I have ever seen a picture of the back of the HT3. I have seen close-up views of switch but never complete view.
Does anyone have a rear view of the HT3? If possible :scratch:Would someone tell me the following  Dimensions:  :lol:
1. distance from cabinet bottom to center of woofer
  2. Width of base* cabinet
      3.   distance from Base cabinet to center of the woofer
* Base cabinet= the enclosure which the houses the woofer.
Re: Back Side of the HT3
« Reply #1 on: 12 Feb 2010, 12:11 am »
to the bottom of the cabinet or bottom of the plinth?
Spikes?
Vulcan00
« Reply #2 on: 12 Feb 2010, 12:52 am »
Sorry:
I was leaving work in a hurry when I wrote this and did not make it very clear. I am trying to get an idea of the size of the bottom portion which the woofer is in.
First I would like to know the size of the bottom enclosure .  How High is the enclosure?  I figure the width and depth is given somewhere. I can get the volume if I know the "H" of Just the bottom portion.
Second I would like an idea of where the 10" woofer is located.
Harrison
DMurphy
    • SalkSound
« Reply #3 on: 12 Feb 2010, 02:26 am »
I'm still not quite sure what you're asking for.  There isn't any "woofer cabinet."   The design transitions to a slope well above the woofer section.  But the width of the widest part of the cabinet is 12".  The woofer center is about 17.5" above the floor, not counting spikes or cones.
Vulcan00
« Reply #4 on: 12 Feb 2010, 10:21 am »
thanks that gives me   what  I was asking. i did not know if there was a seperate cabinet or not.
