Just got my di-capo-i's..next up osiris vs. mapleshade .
0 Members and 1 Guest are viewing this topic. Read 2467 times.
reddmadder
Just got my MM DeCapo's and am truly amazed at the midrange andalso   the bass. My next step is trying the Osiris stands which I'm using now (without any filler)and then the 10"mapleshade gibralter maple stands. BTW anyone try Quicksilver amps with these speakers? And does filling the Osiris stands with sand make a "great " difference in the sound?
DARTH AUDIO
« Reply #1 on: 27 Jan 2004, 04:08 am »
Fill the stands.. Makes a big difference. You can use Dry sand or buckshot. Also, you can fill the stand with both sand and buckshot. The sand fills in around the buckshot.  :uzi:
reddmadder
« Reply #2 on: 27 Jan 2004, 10:56 am »
Thanks for the tip. I guess I'LL need one mother of a funnel to get all that sand in.
