how to set mini to output itunes over usb?
0 Members and 1 Guest are viewing this topic. Read 1217 times.
stump4545
« on: 11 Feb 2010, 01:29 pm »
where is this setting?
pics of my new system to come.
jaywills
Re: how to set mini to output itunes over usb?
« Reply #1 on: 11 Feb 2010, 01:56 pm »
There are two places to check in OS Tiger, Leopard or Snow Leopard.  One is your "Sound" preferences, which has an output selector (make sure your usb device is connected).  The second is in the MIDI preferences, which for some reason is found in the "Utilities" folder.  It also has an output setting that must be set as well (to the same output as you chose in the "Sound" preferences).  In addition, the MIDI control panel allows you to set the sample rate and bit depth.  Good luck.  Cordially,
stump4545
« Reply #2 on: 11 Feb 2010, 10:03 pm »
thanks for the help
