Audio Mirror T-61 Tube preamplifier
0 Members and 1 Guest are viewing this topic. Read 3358 times.
bunky
« on: 10 Feb 2010, 11:18 pm »
Ok guys, I have a Loc Vu modded GTA SE40 and i am sending another one to him for the same mods so i can run 80 wpc single ended monoblocks. the guy who owns Audio mirror makes two types of SE monoblocks and a linestage that uses a tube rectifier and two 6N1P triodes and i think his little preamp might have really good synergy with my GTA SE40's.does anyone know anything about this preamp and should i pull the trigger on one of these.thanks....WCW III
bunky
Re: Audio Mirror T-61 Tube preamplifier
« Reply #1 on: 27 Feb 2010, 11:01 am »
I recieved the T-61 preamp a few days ago,I talked to Vlad who owns Audio Mirror and builds the amps and he told me he switched from the 2.2uf Sonicaps he was previously using to 2.2uf Jantzen Audio Superior Z-caps and that the T-61 sounds better with the Jantzens. it is very quiet and sounds very good new out of the box he said it will sound even better after 100 hours....WCW III
Ericus Rex
« Reply #2 on: 27 Feb 2010, 01:53 pm »
Macrojack has owned some Audio Mirror stuff.  You may want to PM him.  Zybar too.
