0 Members and 1 Guest are viewing this topic. Read 6325 times.
The first question is not about the amp, but these:1. Speaker efficiency2. Room size3. What you like to listen to and how (LOUD, soft, etc...)(Sorry to be a 'ball hog' but I love these questions!)I would not say there are not any inherent disadvantages to SET, SEP, PP, PP-Parallel topologies. The disadvantages come into play when the amp is not interfaced with everything else correctly.
NiteShade argument looks good. I would suggest this Klipsch RF83, two way 100dB SPL speaker to play with such amp: http://www.klipsch.com/na-en/products/rf-83-overview/
Now you're talking! Their incredible performers for the price and can handle allot of power even though they are efficient. No see for a sub with these things! They perform better than the spec's suggest.
Based on my limited experience with a couple of EL84 and 2A3 amps, I prefer the sonic attributes of the SET over PP. I like the power of PP, but the refinement of the SET is more important to my ear. But as Niteshade implied, the choice of speakers with a SET becomes an issue.
Hi Boys,I see the rated efficiency of speakers as the average of the SPL range, not the efficiency in a bass point, treble or the entirely freq range.
Over the years we have owned PP Triode, SET and SS PP. To our ears the SET is a non fatigueing sound. Yes speaker choices are limited and can get quite expensive when power is needed. The speakeres we use have a sensitivity of 96db. With the darTZeel SS amp plenrt of thrills power and a high fi show. With the SET a relaxing affair with body and soul. Yes the bass is a bit rounder the highs maybe not as extentended but the midrange is more natural and emotional. Is it the phase splitting of the PP vs SET. Lets take Humpty Dumpty as an example. No matter how well he is put back together he is pot the same as before he fell. Now SET does have more disortion and power supply noise issues which require filtering of the mains. The distortion of the SET is more agreeable to our senses than PP which can come across as bright or hard sounding. At one of our meetings the hostwas driving Maggies with a sacreligous 8 watts. A definite no no with Maggies. Right ? Wrong. The sound was glorious until clipping. Now the VTL 150s drove the Maggies much better but the tonality and harmonic stucture was MIA compared to the SET. For low to med volume and accomodating music selection most perferred the SET sound as limited as it was. I believe in the KISS theory. Why would a designer want to split the single, play with feedback and hope to reasemble the original input signal. Are we building a better mousetrap or asking for complicated solutions?charles
They are very,very,very good sounding speakers! The bass response is simply incredible and everything they do is effortless. A three watt low bass note will rattle the room. It's far from mushy or wobbly as well. Are the spec's bogus? I can't say. Could you explain your reason?
