0 Members and 1 Guest are viewing this topic. Read 6324 times.
An Alnico 4.5" driver should be here soon. I built a Simple SE EL34 / KT88 SET amp for my speakers, it's similar to this Decware:http://www.decware.com/newsite/SE34I.htmI use my Simple SE with an Anthem Pre1 6dj8 tubed preamp, and really like the results.
Dave, do you have some inside information on the 4.5 alnico? Louis hasn't given any updates for a long time. -Roy
I like your comment on the 6's intimate image and meat on the instruments. I listen near field and value that over large scale drama. Micro dynamics are very important though. In the past, the best systems for meat on the bones have been tube; sounds like the 30.2 does that pretty well though.Thanks for the info.~Lary
As for driving them, I know tubes or SS will work, but is there any real 'magic' when using low power tubes (say, Decware Taboo). How about the RWA 30.2? Would that offer any better bass control/extension?Sorry for the ramble and thanks for any advice. ~Lary
