0 Members and 1 Guest are viewing this topic. Read 9565 times.
I can't accommodate 2 subs. I already have an older inexpensive Velodyne CHT-8 for HT use in a separate HT system in the same room. So 3 subs are not an option for the WAF. I need a good non ported fast sub to go with the Magnepans, hence the Martin Logan, Velodyne DD and Rythmik subs. They are all non ported.Pesonally, I don't see the point of having 2 subs for my application which is 2ch music with the sub filling in below 40hz, anything above that will be handled by the magnepans. I'm not a bass freak and I want the sub to blend in seamlessly and disappear.I do see the point of dual subs in a large room or when they are crossed over at a higher frequency.
At your budget, any of the REL's would be the best choice. You can even find used REL Strata III's for under $600 on www.audiogon.com. Fantastic subs. www.sumikoaudio.net
