Anyone still using an Ariston Audio RD IIs turntable?
0 Members and 1 Guest are viewing this topic. Read 4581 times.
motosapien
I picked one up (well) used recently.  Has a nice Grace tonearm on it and a heavy metal platter.  Only issue is a soft ticking that I assume is the motor suspension.  With the needle in the run out groove on a record and the gain turned way up there is no audible noise from this through my speaker.  Sill, I'd like to fix that.  Perhaps add a DC motor upgrade.  I've never looked inside a turntable but the motor appears to be rather hard to get to.
I would have to pay alot to get a new deck with a platter this heavy and a tonearm this good.  Any experience with this deck out there?
rcag_ils
Re: Anyone still using an Ariston Audio RD IIs turntable?
« Reply #1 on: 10 Feb 2010, 03:52 pm »
I don't have an Ariston RD11s, but I have a RD11 Superieur with a DC motor and one piece platter. I am not sure if I can help you troubleshoot the noise from the motor without seeing it or hearing it. A bent shaft in the motor may have made the same kind of noise.
Bob Wilcox
« Reply #2 on: 11 Feb 2010, 12:04 am »
Any chance the motor pulley is rubbing against the chassis? There may be a set screw that will allow you to set the height of the pulley on the motor shaft otherwise you may need to adjust the tension on the plinth float springs - not the easiest task if memory serves.
AudioSoul
« Reply #3 on: 13 Feb 2010, 05:20 pm »
  Yes, check that and the belt. Sometimes belts get a spot in them from setting in the motor pully for to long of time.
motosapien
« Reply #4 on: 16 Feb 2010, 11:21 am »
I think the motor shaft bearings are worn.  I suppose I could pull the motor and see if a shop can fix it.
rcag_ils
« Reply #5 on: 17 Feb 2010, 05:33 am »
You need a new motor then
