Another Question for James
0 Members and 1 Guest are viewing this topic. Read 1836 times.
Dilbert
« on: 8 Feb 2010, 04:13 pm »
Hi, is the fixed frequency, 10B crossover 24 db/octave version less expensive than the switched (with different slopes) version?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Another Question for James
« Reply #1 on: 8 Feb 2010, 04:17 pm »
Hi,
Same price for all versions.
james
Dilbert
« Reply #2 on: 8 Feb 2010, 04:21 pm »
Wow, that was fast! Thanks. What is the list price?
« Reply #3 on: 8 Feb 2010, 04:30 pm »
$3,050 US suggested list.
james
werd
« Reply #4 on: 8 Feb 2010, 05:40 pm »
james
$2050.00!! what are you going to do with $1550.00 anyways..?, i will give you $1000.00.... :) :thumb:
Dilbert
« Reply #5 on: 8 Feb 2010, 05:52 pm »
Yes, you should be entitled to "suggest" your own list, too!! :lol:
