Conrad-Johnson PV-3
0 Members and 1 Guest are viewing this topic. Read 1958 times.
starkiller
Conrad-Johnson PV-3
« on: 8 Feb 2010, 05:28 am »
Was wondering if a soft start can be added to my C-J PV-3??
Niteshade
    • Niteshade Audio
Re: Conrad-Johnson PV-3
« Reply #1 on: 8 Feb 2010, 10:32 am »
Why do you want to do that?
It is always best to turn the preamp on first before the amp. That way everything can get settled in and there will be any pops, whooshes, etc...
I don't think you need a soft start- it doesn't matter to the tubes. It's a myth that it works for the small tubes we use. It applies to big tubes that operate in the KV region. Big kilowatt+ amps have a timed HV kick in relay.
« Last Edit: 8 Feb 2010, 01:09 pm by Niteshade »
starkiller
« Reply #2 on: 8 Feb 2010, 04:42 pm »
Because i forget sometimes to turn the preamp on first and the speaker fuses blow on the amp :)
