screw size
0 Members and 1 Guest are viewing this topic. Read 1053 times.
drmike
screw size
« on: 7 Feb 2010, 03:08 pm »
anyone know the size of the screws used to hold the top of the constatine/pardisea dac cover on?
thanks,
drmike
srb
Re: screw size
« Reply #1 on: 7 Feb 2010, 03:40 pm »
Although I no longer have the unit, I did buy a set of black screws to replace the gold ones.  The front panel screws are the same as the top screws.  I think they were metric M4 that take a 3mm hex wrench.
I got them at an Ace hardware, so if you have a larger Ace that has a good selection of specialty screw bins, I would take a screw down there to verify.
drmike
Re: screw size
« Reply #2 on: 7 Feb 2010, 04:14 pm »
thanks,
drmike
decal
Re: screw size
« Reply #3 on: 7 Feb 2010, 07:39 pm »
Ace is the place with the helpful hardware man. :eyebrows:
