0 Members and 1 Guest are viewing this topic. Read 7527 times.
My uDac (black) and my friend from works uDac (red) are both slightly louder on the left side. Nuforce is kindly sending me a replacement. I hope it does not have the same problem.
Hello,I apologize for not clarifying my view. There are many factors involving the imbalanced channels of the Udac. The mechanic of every Udac cannot be perfect, the volume control might have some deviation curves. Second, a rather sensitive headphone can amplify the above problem. In addition, there is a possibility that the Dac and the headphone don't match. I've done some reading myself just now, and I have found only a minority is experiencing this problem. So there might be a good chance that you receive a less deviate Udac through replacement. Thank You for your time.Best Regards,LoganNuForce
TrackingHeadphones have one channel for each ear, so it is vital for good performance that both sides are identical. Our test system produces the graph below, which shows the tracking across the frequency range of 80 to 2kHz. If the line is at 0 percent, that indicates the sound at that frequency is identical in both channels. If it goes above that line, the left channel is stronger, and if it goes below, the right channel is is putting out more.
The transducers have much higher channel tracking issues. You can read the various measurement presented in some headphones/earphones measurements: http://www.headphoneinfo.com/d/reviews.htm
Monster Turbines (quite bad)
The volume control at the low volume setting still tracks within 1dB, however, check your earphone's performance - almost all IEMs except the very top-end models exhibit significant deviation between L and R buds.
Thank you for the information, nuforce-casey, but please understand that the characteristic you've shared is not the issue we're experiencing.Looking at the channel tracking testing you've referenced, I found no mention of the overall volume level used while testing. The problem we're describing is very specific to low volume only (as set on the volume knob of the uDAC).Furthermore, the channel deviations described by the tests you've passed on are in the higher (above human voice) frequencies only (>3kHz). The problem we're describing is as broadband an effect as simply making a (R/L) balance adjustment.I tested my faulty uDAC with both decent and cheap headphones, over the head and in ear. Exactly the same problem regardless of headphone. It's not just a difference between the channels at certain frequncies--as the volume is reduced to the quietest levels, the sound moves to a single (same in both earphones) channel before the overall volume goes to zero.The problem does not exist on my laptop's headphone out jack. The channel imbalance at low volumes we're describing is a problem with the uDAC. And it's pronounced.
My experience with volume diferential is from 7:00 the off position to 8:15-8:30. After that R/L balance is achived..in my ears anyway.
Even with my sensitive IEM's {TF10's} I find I listen at a level beyond 10:00 so the imbalance I hear is a non issue.
Furthermore, the channel deviations described by the tests you've passed on are in the higher (above human voice) frequencies only (>3kHz). The problem we're describing is as broadband an effect as simply making a (R/L) balance adjustment.Quote from: nuforce-casey on 12 Feb 2010, 08:07 pmOn those chart examples, you should see that the volume deviation (Monster Turbine) is consistent over the low frequency at -2dB, and the Vmoda +3dB. The wide swing at high frequencies are actually not that easy to hear, because they swing between R and L with very limited (notched) frequency bands.
Looking at the channel tracking testing you've referenced, I found no mention of the overall volume level used while testing. The problem we're describing is very specific to low volume only (as set on the volume knob of the uDAC).Quote from: nuforce-casey on 12 Feb 2010, 08:07 pmI want to show were the gentle, nearly straight lines that falls between 20 to 1kHz in those examples.
That said, Nuforce would gladly exchange the uDAC and I would be interested to measure the returned unit. You should send a note to our helpdesk.
I had been holding off returning my uDAC to hear if NotoriousBIG_PJ's replacement fixed the issue. But knowing now my return will allow you to experience the issue for yourselves, I think I'll do so.
I tested the one that you sent back, there was slight differences compared to a functional one. I am not sure why the replacement Udac was defective as well, because we don't get much customers complaining about this issue. Sorry for the trouble, please return the unit in the following manner. We will process your refund promptly once we receive it.
Thanks,LoganNuForce
http://www.nuforce.com/hp/support/analog-volume-graph.html
