does aiff keep track and album info on itunes?
0 Members and 1 Guest are viewing this topic. Read 2045 times.
stump4545
« on: 6 Feb 2010, 05:14 pm »
when burning to aiff using itunes do you lose album and track info?
pardales
Re: does aiff keep track and album info on itunes?
« Reply #1 on: 6 Feb 2010, 05:16 pm »
I have ripped to AIFF and have maintained all track and album info, including album art.
stump4545
« Reply #2 on: 6 Feb 2010, 06:13 pm »
just started ripping my cds into itunes in aiff.
 i am using a mini with external iomega hd connected with firewire.
for some reason itunes is finding the album and track info but not the artwork (some sort of error comes up)
i am connected to the internet.
what am i doing wrong?
srb
« Reply #3 on: 6 Feb 2010, 06:18 pm »
Do you have an iTunes store account?  As far as I know, that is necessary for the feature to work.  If that's not the problem, then let us know what specific error you're getting.
K Shep
« Reply #4 on: 6 Feb 2010, 06:20 pm »
In my experience.  The majority of albums have the metadata on the CD, so once ripped the album art and info is logged.  Some of my older CD's don't have the metadata on the disc, iTunes allows you to right click on the album icon and a drop down appears, click on "Get Album Artwork" and your computer reaches out via the internet to obtain the artwork.
If you are ripping a compilation you need to right click on the album icon, click "Get Info", click "Options" then check the compilation box yes and iTunes will organize those tracks into a compilation.
That is the best way I know how to explain my process.  Others please correct me if I'm wrong.
stump4545
« Reply #5 on: 6 Feb 2010, 06:32 pm »
i am getting unknown error -609.
srb
« Reply #6 on: 6 Feb 2010, 06:45 pm »
The simplest thing to try first is to
Sign out of the iTunes Store (with the dropdown at far right next to your username/email address)
Quit iTunes
Start iTunes
Sign into the iTunes Store
Hopefully that will work.
stump4545
« Reply #7 on: 6 Feb 2010, 08:27 pm »
thanks srb, worked like a charm.
anyway to get album and track info for cds that i already burned to my hd.  since i didn't get the info before they burned the tracks titled,  "Track 1, Track 2, Track 3...etc
srb
« Reply #8 on: 6 Feb 2010, 09:12 pm »
To retrieve the Track Names you will need to have the Artist and the Album entered for each track of the album.
If this data is not already entered, then:
1. Select All of the tracks for an album
2. Click File > Get Info
3. Enter the Artist and Album (as they appear in the Gracenote.com database)
Then with all of the tracks selected, click Advanced > Get CD Track Names
If it doesn't find them, then the Artist and/or Album may be listed differently in the database.  You can go to Gracenote.com and search for the album to get the correct Aritst and Album name.
