Electrolytic Cap Search
0 Members and 1 Guest are viewing this topic. Read 2291 times.
OlesonMD
« on: 5 Feb 2010, 11:57 pm »
Does anyone have a source for the following:
Nichicon 470uf 16v Radial
Nichicon 1000uf 25v Axial
Panasonic or Rubycon would be OK as well. I need 2 of each size.
poseidonsvoice
    • 2 channel/7 channel setup
Re: Electrolytic Cap Search
« Reply #1 on: 6 Feb 2010, 12:34 am »
Nichicon 470 uf cap
Nichicon 1000uf
Hint: Google is your friend.
Anand.
« Last Edit: 6 Feb 2010, 07:52 am by poseidonsvoice »
OlesonMD
« Reply #2 on: 6 Feb 2010, 12:41 am »
Google has been exhausted in this search.
It appears that there is no such animal in a single manufacturer.
jtwrace
    • TIPP YouTube Channel
« Reply #3 on: 6 Feb 2010, 12:45 am »
 :nono:  Then google hasn't been used properly.   :)  Anand got you the links to purchase them.   :thumb:  Just click on the links he provided.
Good Luck with them!
poseidonsvoice
« Reply #4 on: 6 Feb 2010, 07:49 am »
Yes, the axial Nichicon 1000uf/25V cap isn't available by Digikey here in the U.S. but it is available from the U.K. site for some reason. If you can work with the radial Nichicon 1000uf cap, then you should be good to go. Might want to do a search for axial capacitors in general from Digikey since you are open to other company types. Here is a search I just did for axial 1000uf/25V caps at Digikey.
Here is a Panasonic 470uf/16V radial cap from Newark.
Here is a Nichicon 1000uf/25V axial capacitor again from Newark. But they throw this $20 "freight" charge on you  :duh:
Best,
Anand.
Niteshade
    • Niteshade Audio
« Reply #5 on: 6 Feb 2010, 11:31 am »
www.mouser.com
Other brands are fine! If you want a higher quality cap, go with a higher temp rating, such as 105.
OlesonMD
« Reply #6 on: 6 Feb 2010, 12:30 pm »
Thanks for the replies!
Mouser is good as they are here in Texas.
Newark supply is good, and another one, Great Plains Electronics.
I ended up with a 105 temp Panny and a 85 temp Nichicon. Could not find the Nichicon 1000uf 25v axial in a 105 rating.
Thanks again!
