Custom 45 or 2a3 SET $550
0 Members and 1 Guest are viewing this topic. Read 1910 times.
Angaria
« on: 4 Feb 2010, 04:47 pm »
Have this excellent SET listed on audiogon for $500 - 10% off for ACer's.  Comes with slightly used, vintage Tungsol 45's.  If you want a pair of electroharmonix 2a3's let me know.
Amplifier was designed utilizing four tubes, one 6SL7 (Input) can be substituted with 5691 and two 45 (Output) can be substituted with 2A3 and 1-5Y3 (Rectifier) can be substituted with 5U4,GR34 or 5AR4. This amplifier features a single pair of inputs, volume control, power switch, power indicator, right/left speaker terminals (4 Ohms) and circuit protection. This amplifier layout has been carefully designed using a combination of Vintage, and high quality components.
These high quality components are brand new and consist of Hammond filter choke, Hammond Filament transformers, Heyboer output transformers, Illinois electrolytic capacitors, poly capacitors, carbon resistors, gold-plated RCA jacks, speaker jacks, top grade ceramic tube sockets, IEC connector and power switch. Coupling capacitors are poly coupling caps. Illinois electrolytic capacitors are used in the cathode section and Cornell-Dubilier electrolytic capacitors are used in the power supply section. All components are perfectly matched left to right for proper channel balance. This amplifier was designed on a garolite board, with all handwired, point to point circuitry using less wire to prevent hum and all grounds are in the correct places. This design allows this amp to run continuously, with extreme quiet operation. This amplifier has built in volume control and can be used with or without a preamp.
« Last Edit: 29 Apr 2010, 01:24 am by Angaria »
Angaria
Re: Custom 45 or 2a3 SET $450
« Reply #1 on: 18 Feb 2010, 10:33 pm »
thought I had a buyer, but it fell through. TTT
Angaria
Re: Custom 45 or 2a3 SET $550
« Reply #2 on: 29 Apr 2010, 01:24 am »
Now on audiogon http://cgi.audiogon.com/cgi-bin/cl.pl?intatube&1277688088&view&1272504144
Will to trade for nice F3 or F5 clone.
Angaria
« Reply #3 on: 2 May 2010, 05:28 am »
Traded away, thanks Roscoe.
