Speaker box info and calculators
0 Members and 1 Guest are viewing this topic. Read 11039 times.
S Clark
« on: 3 Feb 2010, 09:06 pm »
There are several good programs for helping design speaker boxes.  If you find some that I have left off, please post and add them.
Basic info: http://www.diyaudioandvideo.com/FAQ/Build/
Box Calculators
http://www.linearteam.dk/default.aspx?download=winisd
http://www.diyaudioandvideo.com/Calculator/Box/
The Lalena.com site also has basic crossover info and notch filter info.
This site at Madisound looks interesting, but I haven't explored it completely. http://www.madisound.com/services/hifispeakerdesign.php
Duke
    • http://www.audiokinesis.com
Re: Speaker box info and calculators
« Reply #1 on: 4 Feb 2010, 02:10 am »
Here's a box calculator that you can download (the demo version is usually adequate):
http://www.ggimages.com/spsim/index.html
All you need to input is Fs, Qts, Vas, and Qes.
I'm suspicious of the results the vent calculator gives you for multiple vents, but otherwise I think it works well.
Duke
edit 12-27-10:  That link no longer works; I've been unable to re-locate this speaker simulator on the 'net.
« Last Edit: 28 Dec 2010, 03:47 am by Duke »
kinku
« Reply #2 on: 28 Mar 2013, 10:36 am »
SPEAK at Gedlee.com is free now. Not very friendly for a beginner but if you are patient enough can work it out.
