BCD-1 vs mac min+BDA-1
0 Members and 1 Guest are viewing this topic. Read 1203 times.
qkot
« on: 3 Feb 2010, 02:13 am »
Does anyone have any experience comparing a BCD-1 with a mac min+BDA-1 combo?
I want to go the digital route, but after listening to the BDA-1 with a poor transport, (sound was quite bad when compared to the BCD-1) I am skeptical that a computer+dac combo can compete with a good quality cd player.
joey116
Re: BCD-1 vs mac min+BDA-1
« Reply #1 on: 3 Feb 2010, 06:03 pm »
Interesting question qkot, archiving CD's to a computer \ server, are you not at the mercy of the computers built in optical drive? probably a $30 component at best, if not, why do people spend $$$$$ on hi-end transports?
Sorry if I hijacked your thread but we seem to be thinking the same way.
srb
« Reply #2 on: 3 Feb 2010, 06:27 pm »
Interesting question qkot, archiving CD's to a computer server, are you not at the mercy of the computers built in optical drive? probably a $30 component at best, if not, why do people spend $$$$$ on hi-end transports?
No, you are mostly concerned with the software used for ripping and it's error correction protocol.  The error correction component of the ripping software can extract a bit perfect file to the hard drive.  If the computer has a poorer quality optical drive, the error correction may take a little longer and the computer may work a little harder, but the end result should be the same bit perfect file.
A CD transport must perform it's error correction in real time, on the fly.  A good transport will also output the digital stream to a DAC with less jitter (mistiming) in the signal.
