0 Members and 1 Guest are viewing this topic. Read 34375 times.
To make SURE you produce solder joints like this, it is ESSENTIAL to *constantly* clean the tip of your soldering iron. A wet sponge is *usually* the best way to clean the smoldering flux from the tip of the iron prior to soldering each new joint. Frank includes solder with the "Super PAS Three Rebuild Kit." USE IT! Don't even THINK about using silver-bearing solder, no matter WHAT your "audiophile" friends tell you!
