DIY Screens - 155" Diagonal
0 Members and 1 Guest are viewing this topic. Read 1423 times.
OlesonMD
« on: 2 Feb 2010, 12:42 am »
You can do this yourself!
Pick your wall and tape off the desired screen dimensions. Float the sheetrock with tape & bed mud, then sand with a wall sander to remove all imperfections.
Paint 2 coats of Kilz primer (spray is better, but you can roll as well) on sanded area.
Next, spray 2 coats of the following: A 3 to 2 mixture of Behr Silver Screen and Behr White Opal Pearlescent (No. 781).
Trim with lumber of your choice.
We have had a number of HT Pro Installers over, and they could not believe this was a DIY project.
Not only is this an awesome screen, you'll have a lot of fun with this project as well!
This is a Blu-ray - Diana Krall Live In Rio
Toy Story - DVD
Planet Earth - BluRay
Black & White - Roy Orbison
« Last Edit: 4 Feb 2010, 06:17 am by OlesonMD »
Bob in St. Louis
Re: DIY Screens - 155" Diagonal
« Reply #1 on: 3 Feb 2010, 05:22 am »
EXCELLENT topic Mr, MD.
Just what the HT Circle needs. Nothing better than a DIY screen.
Kudos to you Sir!  :thumb:
Bob
