0 Members and 1 Guest are viewing this topic. Read 6126 times.
120VAC is the RMS average that would have the equivalent heating effect of 120VDC. The peak voltage of 120VAC would be 120V X 1.414 = 170VAC. The acceptable voltage range of a power supply with a nominal 120VAC input varies with the amount of regulation in the power supply, but I would venture that most electronic devices with regulated power supplies that are rated at 120VAC input can operate from 110VAC to 130VAC. Some may be able to tolerate an even wider range. Although it's not usually specified, I will be interested to hear what Pioneer says their specification is. I use a voltage regulated power conditioner (Rotel RLC-1040), but I have it set to "wide range" so as not to be continually activated for minor normal voltage fluctuations, but to only kick in on major sags or surges, which can sometimes be detrimental to electronics. Steve
You absolutely don't need to regulate your voltage whatsoever! Most electronic equipment are not sensitive to incoming voltage. Your TV will operate just fine with 80 volts as it will with 160 volts. It has an internal voltage regulator. Any kind of voltage regulators for an audio/video system are a complete waste of time.
Guys a distribution transformer's voltage is usually around 126V when measured going to your home
I have seen many components that will not function properly for long periods of time with higher voltages. Most of these products start experiencing problems at 124V+. This is a big problem with much of today's imported Chinese products that were not designed to be run on North American voltages. If the component is not designed with higher voltages in mind or does not have a regulated power supply, some type of voltage regulator is obviously a good thing. I do agree this is not the 'norm' but with so much 'cheap' stuff coming in, there more problems presenting themselves. I doubt this effects most TV's out there as I thought they used regulated supplies but I can only imagine having a steady regulated voltage for a Plasma would be beneficial for long term reliability.
I agree Kevin but another part of the puzzle that has a high failure rate is the transformers. Cheap transformers have no place in audio. I test all my designs from 110V-130V and 220V-240V and all of our upper end products have transformers custom design for the component they are being used in.I do believe voltage regulation is a good thing to have if you have inconsistent voltage. Vishan (spelling?) in Washington comes to mind.
