0 Members and 1 Guest are viewing this topic. Read 3182 times.
The new drive may need to be formatted and a drive letter assigned. Go to Start > All Programs > Administrative Tools > Computer Managment (or right-click on My Computer and select Manage). In the Computer Management console, click on Storage > Disk Management. You should see your new disk there, but it may be unformatted. If so, right-click on the disk and select Format (make sure you are on the correct disk!). After formatting, you can right-click to Change Drive Letter if you want a drive letter other than the automatically assigned one. Steve
Robin - This looks like an Apple commercial with ole PC struggling to make Microsoft change a light bulb in less than 300 steps. Mac is watching and trying not to laugh. Installing Windows 7 in a new HP desktop at my house took half a day. Installing Snow Leopard in my I-Mac took about 20 minutes. I don't mean to dis you in your time of desperation - I'm just struck by the contrast and I wonder why PC people put up with it.
You chose correctly, Robin. If you replace a hard drive on a Mac with an unformatted drive, you will have to launch Disk Utility, then select the drive, then select the Partition tab, then set the number of partitions, then choose the format, etc. Same thing, just a different interface. Robin, feel free to PM me if you run into anything (if you want to avoid non-constructive comments from Mac fanboys - I have supported both platforms and have spent many hours troubleshooting Mac problems as well), but I'm pretty sure you're on your way. Steve
