F/S VMPS RM30s, Larger Sub w/MegaWoofers and 1000-watt Sub Amp
0 Members and 1 Guest are viewing this topic. Read 2641 times.
celiasdad
Full-range system: VMPS RM30s (many upgrades), Larger Sub, and dedcated 1000 watt sub amp.
Less than a year old and in pristine shape 9/10.
Asking $3650 - Buyer pays shipping. I recommend Pilot Air frieght or a similar trucking company. I can load all on a pallet. Zip Code is 80905. Retail prices are included for your reference. Contact me:[email protected]
Package includes:
• 2 VMPS Ribbon Monitor 30-- ($3195.00 not including upgrades)
• Constant Directivity Wave Guide - RM30 CDWG = ($239)
• Black MLS Piano Black Cabinet (Diamond Lacquer finish) Piano Black MLS $(400.00)
Complete custom SoniCaps upgrade – all Sonicaps capacitors in the crossover (the most important option, much, much better than the Auricaps) - ($650)
• Woven Carbon Fiber MegaWoofers 6.5" Megawoofers for RM30 set of 4 ($380.00) New 6.5" woofer is an evolutionary development of a driver first built 5 years ago. It is a true lowbass, not a midbass, and as such features a four-layer 1.5" voicecoil, 7 mm of Xmax, a woven carbon fiber cone with natural rubber surround, 40oz magnet, and 250W of power handling.  It is quite simply the finest quality, and best sounding, such loudspeaker ever produced. Made in USA.
• Analysis Plus Cables wiring – ($400 pr)
Larger Sub w/MegaWoofers --- ($839) (NASA's Langley Research Center has purchased two Larger VMPS Subwoofers as a source of 118+ dB, 20 Hz tone bursts. The Larger Subwoofer was the only commercially available system capable of so doing.)
Dayton HPSA 1000-R Sub Amp ($498)
Dayton's newest amplifier features an adjustable low-pass crossover, adjustable phase and a parametric EQ. The HPSA-1000R also has an auto on/off 12v input for automated systems, removable ears for rack mounting and pop-out stealth knobs to prevent any accidental changes to the settings.
Features:
* Class AB output stage for powerful, clean output
* Patented tracking down converter power supply increases headroom and efficiency
* Low frequency parametric EQ allows you to boost or adjust the sound to your room
* Advanced soft clip circuitry improves headroom and protects woofers
* Triggered or auto on/off and adjustable phase for easy integration into any system
* Perfect for powering built-in or infinite baffle subwoofer installations
* Low heat emission--no fan required for most applications
* 1,000 watts RMS output into 4 ohm mono load
* Five Year Warranty
* Dimensions: 17-1/2" W x 3-7/8" H x 14" D
VMPS site:http://www.vmpsaudio.com/
VMPS Review: http://www.positive-feedback.com/Issue16/vmpsrm30.htm
Situation forces sale. My loss = your gain
spacedghost
Wow
This will be the last time I look at this thread  :wink:, you live wayyy to close (and I enjoy being married..:) )
Good luck with the sale!
Shaun
celiasdad
Spaceghost, If you do indeed live that close and no shipping would be involved I'd be willing to give you a very good discount off the asking price...
Cheers, j
