SOLD: Dual ACI Titan II LE subs in Rose Walnut
0 Members and 1 Guest are viewing this topic. Read 4910 times.
TomS
« on: 30 Jan 2010, 01:00 am »
Beautiful matching sequentially numbered pair of highly-rated ACI Audio Concepts Titan II LE subwoofers in “rose walnut” finish.
These are classic sealed 12” subs with smooth roll-off, ideal for integration into a 2ch music system with planars, open baffle, or typical box speakers. Easily competes with sealed RELs and others of similar design. Because of their high output capability, they also work well in a home theater setup, which is how I used them until recently.
These are in terrific condition and the deep finish is truly beautiful to look at. There are a few very minor cosmetic blemishes here and there, but they cannot be seen from more than a couple feet away so these seem worthy of an 8 to me. They are functionally perfect and include the original brass cone points, speaker level adapters, manual, and foam filled double boxes.
$1300 for the pair of subs.  Will not separate.
Please note this is for BOTH subwoofers and does not include shipping or Paypal fees, if used. The fully packed shipping weight is 83 lbs each. I would prefer a local deal within 150mi of Fort Wayne, IN to avoid shipping these beasts across the country, and would make it worth your while if that option works for you.
Note: I also have an Onix R-DES sub equalizer available. This is the same one ACI sold with all of their subs during that period and provides a simple, low cost way to knock down a few room peaks.
Link to Audiogon ad:  http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1269996334&/Audio-Concepts-%28Aci%29-titan-ii-
Thanks for looking!
Tom
Manufacturer specs:
Frequency response: 20-250 hz +/-3db
Crossover: Dual adjustable low-pass 35-250hz, 12db/octave filters for 24db/octave total
Sensitivity: Adjustable
Dimensions: 22 3/4” tall, 16 1/2” wide, and 16 1/2” deep
Weight: 70 lbs
Special circuitry: Protection circuitry, Woofer behavior control, High-pass outputs
Woofer: (dnwd. fire) Proprietary 12” cast-frame long throw woofer
Rec. RMS Power: Built in amp delivers 250 watts RMS <.5%THD
I'm a horrible photographer but there are more pics here in my gallery here http://www.audiocircle.com/index.php?action=gallery;area=browse;album=2677
« Last Edit: 3 Feb 2010, 09:33 pm by TomS »
TomS
Re: FS: Dual ACI Titan II LE subs in Rose Walnut
« Reply #1 on: 30 Jan 2010, 06:32 pm »
Bump for the weekend.  Rumble, rumble...
nature boy
« Reply #2 on: 30 Jan 2010, 06:43 pm »
Tom, wish my wife would let me get subs for my HT system, cause I would jump all over these.  :bawl: :bawl: :bawl: :bawl: :bawl: :bawl:    You might want to update your Agon link, it does not seem to be working for me.  Good luck with your sale.
NB
TomS
« Reply #3 on: 30 Jan 2010, 06:47 pm »
NB
Thanks.  Bad link fixed.  By the way, these do have generally very high WAF  :eyebrows:
nature boy
« Reply #4 on: 30 Jan 2010, 09:32 pm »
It's not the looks, it's that she doesn't want me to have ANY subs.  Quote :"the speakers you have are loud and go low enough".  She just doesn't understand.  :duh:
NB
AB
« Reply #5 on: 30 Jan 2010, 10:05 pm »
Those are "End Tables"
What sub woofers? I don't know about any sub woofers. Sure, all the best end tables get plugged in these days...
TomS
« Reply #6 on: 30 Jan 2010, 10:09 pm »
Now that's the right attitude  :thumb:
TomS
« Reply #7 on: 31 Jan 2010, 01:14 pm »
Sunday rumbler...
doug s.
  • makin' music
« Reply #8 on: 1 Feb 2010, 02:51 am »
NB
tell her she can turn 'em off when she's listening/watching, & you aren't around!    she doesn't want you to have subs?!?  that's grounds for diworce!
doug s.
TomS
*** SALE PENDING ***
TomS
Re: SOLD: Dual ACI Titan II LE subs in Rose Walnut
« Reply #10 on: 3 Feb 2010, 09:34 pm »
SOLD
