0 Members and 1 Guest are viewing this topic. Read 19719 times.
Oh what irresistible fun for little kitties to see something move around and around...I have two, and now have my system behind closed doors.It's a bit more of a bother changing sides now (I normally use an auto table, so at least I don't have to run to lift the needle from the record!)Enjoy the Grado! The Longhorn mod likely improves even the higher end series doncha' know. Anything you can do to increase tracking prowesss of any Grado helps it wonderfully. What's left is clean, open and natural sound with a low end that makes most other cartridges sound sick John
With your record I would make sure to replace the little stylus gard on the Grado whenever you're closing the system down for the night.Good luck and enjoy.
Kill the cat, put the bong down(Electric razor brush??) and switch to digital when loaded!!
John the Longhorn mod has crossed my mind but I thought a cart at this price point wouldn't need it. Maybe after I have it for a while I'll consider it. Do think it can be done on wood body carts?Ric
Blame Wayner. He suggested the razor brush
I have the Reference Series Sonata on my VPI and it has HUM. A bit less hum with the SDS at 72 volts. A bit less with an AQ PT-9 (my PT-6 has a bad ground somewhere). A bit less with the SAMA. But hum nonetheless. I may move it to my Linn Sondek which, with a Linn Adikt cartridge has NO hum). Good luck! If it's a MC (mine is moving iron) you may not get the hum...I couldn't tell which one your getting from looking at the Grado site. Looks like there's a Reference in the Reference series and in the Statement series. And a Master in each series. But maybe not a Reference Master??? Confusing!Paul
