0 Members and 1 Guest are viewing this topic. Read 3142 times.
Rather than buying a seperate CD player, invest in a good DAC.
Hello!I am considering an oppo BD 83 for a blue ray/dvd and cd player. What have been your experiences with the Oppo BD 83? Some say the BD 83 SE model is better for music? Would you consider the base model for blue ray then buy a separate cd player?What are your experiences? What are you pleased with?Thank You!P.S. This will be used in a 5.1 Songtower home theater/ 2 channel set up
possible streaming from my mac laptop or other device. Not sure how I will accomplish the streaming part but am learning and working on one piece at a time.
2) I assume I would have the blue ray player hooked up by hdmi cable. Not sure what it means to have it hooked up by analog?
I'm with you, mathgeek; streaming is just sooooooo cool. I'll never go back.
1) For the minimalist approach is it wise to buy the Oppo Bd 83 standard version or the Oppo BD 83 SE or something else?2) I assume I would have the blue ray player hooked up by hdmi cable. Not sure what it means to have it hooked up by analog?
