AVA's Insight+ Pre-Amp and DAC Meet the Felix
0 Members and 1 Guest are viewing this topic. Read 3039 times.
WGH
« on: 26 Jan 2010, 04:34 am »
Note: For those who are unfamiliar with the Felix project, start here.
I've had all the parts and circuit boards from the group buy since April 2008 but work has been non-stop until recently so I finally got a chance to throw together a Felix to see what it would do. I have enough parts to make 4 so I started with the 3A version using the CoilCraft P3717-A 27mH CMC and the Vishay F1778 X2 caps. Since the box will never been seen I used 1-1/2 Radio Shack 270-1805 6"x3"x2" plastic project enclosures. I cut the 2nd box on a band saw and joined the two together with screw pins and ABS plumbing glue resulting in a strong ghetto box. The exotic 14/3 wire, Leviton CR15 outlet, Leviton plug, in-line fuse holder and 3A slo-blow fuse was sourced from my local Ace Hardware.
I bought the Insight EC pre-amp, DAC and 440 amp in the fall of 2008 and they sounded so good that the Felix project was now a low priority. The + upgrade with new op-amps made everything sound even better. The stereo is also the centerpiece of the 4/1 surround sound home theater setup, so while I was trying to track down some hum I remembered the Felix filters.
I fixed the hum without the Felix but now I had this box laying around and I thought what if...
I didn't expect to hear a change knowing how well designed AVA electronics are but boy howdy was I wrong. Low level detail like room depth now emerge from the background. Instruments now have more space around them and the living room's front wall disappears, cymbals shimmer and decay naturally. Digital music is smoother which means it can be played louder and vinyl is magical with instruments and vocals floating in space.
As with any power line filtering YMMV, no dedicated AC lines at this old house so perhaps the benefits of a Felix won't be as dramatic in another setup. I have 3 more to make (eventually) using the JW Miller chokes. If they all work as well I would consider loaning one out to see if this is a fluke or if AVA electronics really benefit from a Felix.
Wayne
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
Re: AVA's Insight+ Pre-Amp and DAC Meet the Felix
« Reply #1 on: 26 Jan 2010, 04:57 am »
Nice work.
Gordy very kindly sent me a Felix when I thought that I might have had a dirty AC problem.  My problem was a noisy (Frank diagnosed the problem) cheap Philips DVP.  I have a separate dedicated line for the preamplifiers, DAC, and CDP and a separate dedicated line for the amps.  The lights, computer, and other electrical devices are on another circuit.  The Felix didn't seem to make a difference in my system, but many people have reportedly used them with great success.
What components are connected to the Felix?
WGH
« Reply #2 on: 26 Jan 2010, 05:24 am »
Right now just the pre-amp and DAC, there doesn't seem to be much change, if any, with the Cornet2. The amp is plugged into the wall, with only 3 amps to play with I have to be careful. I plan to put a higher amp Felix before the Panamax so the DVD, digital tuner, and surround processor get a filter.
I have lights, computer, and other electrical devices on the same line so a little filtering helps a lot.
JerryM
  • Where's The Bar?
« Reply #3 on: 26 Jan 2010, 05:36 am »
Looks as pretty as some doors I've seen.  :thumb:
Nice, nice work.  :beer:
How cool that it worked, too!
