0 Members and 1 Guest are viewing this topic. Read 8892 times.
I would think that is a good thing because on the warped recorded the grooves are no longer parallel to the platter, and so the shift in azimuth by the uni-pivot allows it to track the grooves more "accurately", no?
If you have an SDS speed controller, you can compensate for this, but will have to rely on a strobe disc to dial in the correct speed, as the digital read-out of the SDS unit will be off.Wayner
Good afternoon Wayner, FWIW, you must ALWAYS use the strobe disc, for the two digital readouts on the SDS only indicate voltage (VAC) and line frequency (Hz).Regardless for those with a AC synchronous motor, as John said, it's a very worthwhile upgrade !As for the warped record issue with the uni-pivot arm, myself I do not have any problems what-so-ever given the fact that I utilize the VPI perf ring in combination with my BDR clamp.
Still using those cables I made you?
