What wire to replace Monster Cable
0 Members and 1 Guest are viewing this topic. Read 1454 times.
mosawdust
« on: 24 Jan 2010, 06:06 pm »
I'm rewiring the sub section of my ST/R's and eliminating the toggle switch. I don't really understand the full purpose of the toggle to begin with. For full range operation, jumpers are required to be soldered to the toggle elimaniting the ability to biamp or biwire. Anyhow,
What would you recomend to replace the old monster cable?
Brian Cheney
    • http://www.vmpsaudio.com
Re: What wire to replace Monster Cable
« Reply #1 on: 24 Jan 2010, 06:14 pm »
We currently use Analysis Plus 14 gauge flat wire.
mosawdust
« Reply #2 on: 24 Jan 2010, 06:23 pm »
Thanks Brian, Can I get this through you?
Brian Cheney
« Reply #3 on: 24 Jan 2010, 06:40 pm »
Yes, it's $2.50/ft per conductor.
