USED Niteshade Audio Beacon Two Preamplifier (What a deal!)
0 Members and 1 Guest are viewing this topic. Read 2158 times.
Niteshade
    • Niteshade Audio
A great deal on a great preamp:
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1268492252
Tube rectified via a 5Y3 or 5AR4 rectifier
DC Filaments with a 50 Amp bridge rectifier and large filter caps
Our time tested anode output circuit
High efficiency DC Link capacitors, the best available
Autumn Red Metallic super high gloss finish
Brass/Gold RCA's
High current input selector (noiseless)
NOTE: Whoever purchases this will get a 1 year warranty from me. This is an extremely well built preamp that sounds fantastic.
Niteshade
    • Niteshade Audio
Re: USED Niteshade Audio Beacon Two Preamplifier (What a deal!)
« Reply #1 on: 26 Jan 2010, 01:32 pm »
I build my gear to last...and sound very good. Proprietary parts are never used. You will never find modules dipped in epoxy that cannot be repaired and various other disasters waiting to happen, such as traces that can be lifted off of printed circuit boards because they are merely glued in place.
I believe it is important to make gear to last and be easily repaired if the need should ever arise. Shortcuts are not an option. Mass production is clearly not an option. If I do not like it, it will not be done. Circuits should be easily traceable so any qualified tech can work on them. Wire crimps and wraps should be properly made so they hold well, yet are not a disaster to remove. It's difficult to express how important these qualities are, but you must know it takes skill and extra time to build and design equipment with these qualities. Point to point wiring is time consuming and must be done right. Niteshade products are based on a 1920's through mid 50's approach to wiring. An industrial approach enables short signal paths and easy repair. We're mirroring precisely what Baldwin, Conn, Fisher. Scott, Atwater Kent and others have proven to work through the decades. I think this should be very,very pertinent information that goes towards a buyer's decision to purchase something.
The Beacon Two my customer has listed is a prime example of excellent craftsmanship and extraordinary superb sound. The price is right and the finish is fine.
If you have any questions regarding this preamp, don't hesitate to ask me or the current owner.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 26 Jan 2010, 01:39 pm »
Why is he / she selling it?
Niteshade
    • Niteshade Audio
« Reply #3 on: 26 Jan 2010, 02:09 pm »
I did ask him and was told he required a darker sounding preamp. The rest of his system must be warm sounding. Beacon Two is not at all dark. As he states, it's rich sounding. It does a very good job of extracting detail and doesn't veil anything. I should add that there is nothing within the circuit designed to boost or cut any part of the audio spectrum.
Niteshade
    • Niteshade Audio
« Reply #4 on: 30 Jan 2010, 01:09 am »
Still up for grabs!  :D
This preamp is complimentary to either tube or solid state amplifiers. I tried it on both and was very impressed with the performance.
