NHT X2 Electronic Crossover
0 Members and 1 Guest are viewing this topic. Read 1897 times.
Doug Ravizza
« on: 23 Jan 2010, 11:47 pm »
Original owner - Less than 1 year old,  used in my system for ~ six months.
Like new condition.
MSRP $399.00
Factory blurb:
NHT's 2 Active Crossover is your control center for passive subwoofers. It provides extensive front-panel control of all the bass frequency parameters necessary to integrate subwoofers with monitors or other satellites. The controls also help eliminate many common low frequency problems caused by room interaction.
The X2 can operate as either a single channel (mono) or two-channel (stereo) unit via a switch located on the rear panel. Operating the X2 in stereo mode allows the addition of a second subwoofer, for greater bass reinforcement without the expense of an additional crossover.
Two sets of inputs and outputs on the rear panel of the X2 -- differential XLR balanced as well as unbalanced RCA connections – allow for easy hookup with all types of receivers, preamplifiers and surround processors. A three-position, high-pass filter switch (50Hz, 80Hz, 110Hz) controls your monitors' low frequency cutoff. The subwoofer output gain switch allows either 0dB or +10dB settings. The X1 offers a variety of power mode options: always on, 5-24v DC trigger, or auto-on/off mode responding to audio signals.
Doug Ravizza
Re: NHT X2 Electronic Crossover
« Reply #1 on: 23 Jan 2010, 11:49 pm »
Oops forgot, asking $190 plus shipping.
