external harddrive for new mini vs. bigger internal hd
0 Members and 1 Guest are viewing this topic. Read 2065 times.
stump4545
is it better for to have audio files on an external hardrive or should i just get order a mini with a bigger internal hardrive instead?
Crimson
Re: external harddrive for new mini vs. bigger internal hd
« Reply #1 on: 22 Jan 2010, 04:49 pm »
Just run your OS and other applications on your internal and keep your library on an external(s), preferably firewire.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 22 Jan 2010, 04:57 pm »
agree 100%
If you've got money burnin' a hole in your pocket, install a SSD in the Mini for the OS and still get a big external HD.
See this thread:  http://www.audiocircle.com/index.php?topic=76612.0
4th post down
mshan
« Reply #3 on: 22 Jan 2010, 05:18 pm »
Two hard drives presumably means greater noise (plus possibility of second fan in external enclosure such as the Newer Tech Ministacks (open box ones are often available at a discount from Macsales.com).  If you go this route, I think you will want an external enclosure that wakes and goes to sleep with main computer, not stays on all the time unless you turn power switch off.  The Ministacks do this (though blue light stays on) and are nice if you need more usb or firewire ports, but fans is rather noisy when it spins up.  Antec MX-100 is fanless and has appeared to wake and sleep properly for me (it also has a blue light that always stays on, but I damped that down with some blue painter's tape over light).
There can also be an ever so slight, possibly perceptible lag in how iTunes responds to changing track selections if you use an external drive.
However, external drive would presumably cheaper than large notebook hard drive.
Personally, I have consolidated all of my media on a Windows Home Server box (Acer Easystore H340), which actually works really well with iTunes over local wireless network.  It shows up right away in OS X Finder and you can read and write, drag and drop, after you log in with user name and password.  Plus Windows Home Server 2003 has folder by folder duplication, so if you have two separate hard drives installed in it, you can select duplication of your music folder and WHS will keep separate copies on the two separate hard drives.
If you have large iTunes library and like to search for specific tracks a lot, having the full iTunes software interface on local computer screen can't be beat.  If not,  AppleTV has nice big screen graphics and is very, very quiet (you can hear notebook hard drive if you ear is right next to it, but the case fan, at least for me, never spins up - top of case acts as passive heat sink.  Mac Mini - older generation ones - had case fan that would often and loudly spin up during use).
If you have your iTunes library located on another Apple computer in house, you could also use something like a MacBook with remote desktop feature and control iTunes interface that way.
K Shep
« Reply #4 on: 23 Jan 2010, 11:47 pm »
I would suggest looking at an external hard drive to store your music files.  Saving to AIFF is the preferred format and the largest file size.  This will free up space on your Mac.  Take a look at my Mini sitting on top of the iOmega Minimax external 1 TB HD.
pardales
« Reply #5 on: 24 Jan 2010, 12:00 am »
I agree.
jtwrace
« Reply #6 on: 24 Jan 2010, 02:47 am »
Here is my Mini with two iomega 1TB drives.  All files uploaded AIFF Encoder.  One drive just stores the music files the other is partioned that backs up the music files and the OS.  I use SuperDuper! for that.
Audioclyde
« Reply #7 on: 24 Jan 2010, 03:18 am »
Any opinion on which are quieter, Iomega or ministacks from macsales?
Randy
K Shep
« Reply #8 on: 24 Jan 2010, 05:35 am »
I just ordered a second iOmega for backup.  Do you have both of the externals powered on at all times?  I have heard its best to keep the backup powered off when not loading.  Longer life?
Mike Nomad
« Reply #9 on: 24 Jan 2010, 05:48 am »
« Last Edit: 11 Nov 2014, 08:37 pm by Mike Nomad »
K Shep
« Reply #10 on: 24 Jan 2010, 06:34 am »
No.  The iOmega is very quiet.  I sit about 5 feet from the drive and I cannot hear it.
Thanks for the heads up Mike.
jtwrace
« Reply #11 on: 24 Jan 2010, 01:47 pm »
Yes, I keep the backup off unless I'm backing up.
