Who can figure this one out?
0 Members and 1 Guest are viewing this topic. Read 1752 times.
droht
« on: 20 Jan 2010, 03:09 pm »
In my office I have a PC which is my source for music.  I run USB out for music, from the back panel of the PC.  I have a printer connected to the PC via USB port on front panel.  I also have a laptop.  Occasionally I move the printer over to the laptop.
So I'm listening to music and working on the laptop.  I move the USB cable from PC to laptop to print something.  I get immediate screeching and static through my speakers.  I unplug the USB and it goes away.  If I just touch the USB connector to the port I get the same noise.
This only happens when the laptop is plugged in.  Running off battery I get no sound whatsoever when inserting the USB cable.  The laptop is plugged in to a different outlet than the amp.  Tried it with and without a Belkin SurgeMaster - no difference.  Amp is a Decco integrated.  It is the new part of the system.  I've had many other pieces in it's place and never had the issue.
Very strange.  Not really something I need to solve, but more of a curiosity at this point.  Any ideas?  Should I be concerned about the Decco?  (it sounds great otherwise)
turkey
Re: Who can figure this one out?
« Reply #1 on: 20 Jan 2010, 04:02 pm »
Sounds like it may be a ground loop of some sort.
Can you try plugging the laptop into the same outlet as the PC and see if that eliminates the problem?
macrojack
« Reply #2 on: 20 Jan 2010, 04:16 pm »
Buy a nice wireless laser printer for + or - $100. It'll disqualify you from edifying cable discussions but everything else is positive. I have a Brother 2170W that is never a problem.
droht
« Reply #3 on: 20 Jan 2010, 04:24 pm »
I can network my current printer, just need to figure out how through security on company laptop.  But like I said, the issue is not serious, more of a curiosity.
I've heard of ground loops issues; never experienced one I supppose.  This just seems odd as it is not an issue until USB connection is made.  Just having the laptop plugged in is fine.
turkey
« Reply #4 on: 21 Jan 2010, 02:06 pm »
The ground loop is possibly being made when you connect the USB cable with its shield that links the grounds of the printer and laptop - which are plugged into different AC outlets if I'm reading things correctly.
lcrim
« Reply #5 on: 23 Jan 2010, 11:39 am »
Do you have enough authorization to share the printer as connected to the desktop PC?  How is the laptop connected to this network?  Is this network at home or at work?
