laser cleaning
0 Members and 1 Guest are viewing this topic. Read 1178 times.
redbook
  • the music is the blood...........
laser cleaning
« on: 20 Jan 2010, 02:54 am »
Has anyone opinions on laser cleanig discs?  :scratch:
alexone
Re: laser cleaning
« Reply #1 on: 20 Jan 2010, 05:53 am »
redbook,
most things i've heard about them were bad. some really had the feeling it would damage the lens more than it cleans it...
i never used cleaning discs.
al.
drummermitchell
Re: laser cleaning
« Reply #2 on: 20 Jan 2010, 06:39 pm »
I could only imagine eventually what that brush on the disc would eventually do to that polished lens,
sweeping across the lens a few hundred times.It'd be like taking a cornbroom to my polished head :lol: :o.
I think distilled water(lukewarm) and a Q-tip(very gently) would work superb.
rollo
  • Rollo Audio Consulting -
Re: laser cleaning
« Reply #3 on: 20 Jan 2010, 07:39 pm »
DO NOT use them. Buy some photo lens paper and lens cleaner for cameras. Never put the liquid directly on the laser. use the lense paper wetted with the solution. Then repeat with dry paper. Have fun. BTW unless you smoke in that room or its been there for several years. Leave it alone. My 2 cents.
charles
