Wondering about phono EQ implementation
0 Members and 1 Guest are viewing this topic. Read 1903 times.
johnmarkp
« on: 19 Jan 2010, 04:02 pm »
I was wondering if the following is possible.  Can I use a Piccolo with the EQ between it and a standard low noise preamp that I built?  The gain of the pre is 26db so I could get up to 52db, then run that into a normal pre.  How would I determine the components for the EQ.  I have read the posts on it here and on DiyAudio and I still am confused.  I am not ready to build, just wondering if it is possible.  The pre is an all tube 6H30 design.
John
hagtech
    • http://www.hagtech.com
Re: Wondering about phono EQ implementation
« Reply #1 on: 21 Jan 2010, 03:50 am »
You could try, but it might not work too well.  One place to do EQ calculations is at:
www.hagtech.com/equalization.html
The other is at KABusa.
jh
johnmarkp
« Reply #2 on: 21 Jan 2010, 04:22 pm »
Jim,
The more I look at it the harder it looks to get it right without doing many prototypes.  I doubt I will try.
John
