Rolling my own speaker wires for use with Icon
0 Members and 1 Guest are viewing this topic. Read 1502 times.
ndurantz
« on: 18 Jan 2010, 07:59 pm »
Hi. I am wanting to roll my own speakerwires to terminate in a banana plug and am having difficulty with two things.
1) Photos showing how to go about it
2) A suggestion as to what/how to strip wires so stinkin' tiny to expose as necessary for a good connection
Hope that make sense. Thanks!
rustydoglim
    • www.nuprimeaudio.com
Re: Rolling my own speaker wires for use with Icon
« Reply #1 on: 23 Jan 2010, 12:51 pm »
The spec on this page http://www.nuforce.com/hp/products/icon/index.php  should provide enough information. A photo wouldn't show anything better since it is hard to show in a photo all those 8 wires with mixed colors.
Be very careful because if you mixed up the wires, that will short the speaker terminals and kill the amp.
timind
  • permanent vacation
« Reply #2 on: 23 Jan 2010, 01:35 pm »
I have a friend with a small gap in his teeth. He bites down on the wire and gets a perfect strip each time. :D
Stager
« Reply #3 on: 23 Jan 2010, 03:33 pm »
Hi. I am wanting to roll my own speaker wires to terminate in a banana plug and am having difficulty with two things.
This works great, and cheap:
http://trade3.audioasylum.com/ca/listing/Speaker-Cables/Belden/1701A/CAT5-cable-for-speakers/25475
Easy - get a wire stripper with a stop screw which you set for the gauge of cable you are using. Set to the right gauge and you'll always get a clean, accurate cut. They don't have to be expensive - I bought mine at Radio Shack.
ndurantz
« Reply #4 on: 23 Jan 2010, 07:07 pm »
Thanks, all! Exactly what I needed. I think I will skip trying to use my teeth, however and go for the actual wire strippers  :wink:
