V-1 Grills
0 Members and 1 Guest are viewing this topic. Read 2347 times.
ebag4
V-1 Grills
« on: 18 Jan 2010, 06:24 pm »
I normally don't use grills on my speakers but I do like the looks of V-1/Super-V better with the grills from the builds I have seen to date.  My question is, how are those grills being made and how are you connecting them to the speaker?  I have a couple of ideas but I have never built grills for a speaker so I though I would ask to find out how you that have built them went about it.
Thanks for any insight you can offer.
Best,
Ed
Hank
Re: V-1 Grills
« Reply #1 on: 18 Jan 2010, 07:13 pm »
I embed 1/4" x 1/4" cylindrical neodymium magnets in baffles before veneering - one at the location of each grill corner.  Also embed one in each grill corner.  Pull the grills off for serious listening and there are no ugly plastic grill sockets showing - no sign of grill attachments.
Danny Richie
Re: V-1 Grills
« Reply #2 on: 18 Jan 2010, 07:29 pm »
What Hank said... and the frames are made from 1/2" MDF.
ebag4
Re: V-1 Grills
« Reply #3 on: 18 Jan 2010, 07:53 pm »
Hank/Danny,
Thanks for the replies guys.
Best,
Ed
tasar
Re: V-1 Grills
« Reply #4 on: 20 Jan 2010, 05:31 pm »
where do you source these magnets and who has a print for the grill boards ?
Hank
Re: V-1 Grills
« Reply #5 on: 21 Jan 2010, 01:54 pm »
If Danny doesn't have a drawing, it would be super easy to do your own.
I ordered quite a few of the magnets from Bunting Magnetics 4 or 5 years ago.  I think they are the N35P250250:
http://www.buntingmagnetics.com/products/magnets/rare-earth/neodymium
mpauly
Re: V-1 Grills
« Reply #6 on: 22 Jan 2010, 02:54 am »
Hit up ebay! Do a search for "rare earth magnet" and you'll get tons of hits in all sorts of sizes.
If you're looking for 1/4" x 1/4", here's one for 100 of them for $15 shipped. http://cgi.ebay.com/100-Neodymium-Magnet-1-4-x-1-4-Cylinder-Rare-Earth_W0QQitemZ120519544563QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0f864ef3
mms3
Re: V-1 Grills
« Reply #7 on: 23 Jan 2010, 02:46 pm »
Do the imbeded magnets only work well with veneer?  Or can it be done for paint too?  Cover them with wood filler?
Danny Richie
Re: V-1 Grills
« Reply #8 on: 23 Jan 2010, 03:59 pm »
You can cover them with anything. They will work right through it.
Hank
Re: V-1 Grills
« Reply #9 on: 25 Jan 2010, 06:36 pm »
Yes, anything.  Just drill your hole without enlargining it, but if you do make it a bit oversize, epoxy the magnet in place.
