Cornet - C8
0 Members and 1 Guest are viewing this topic. Read 1866 times.
Grover
Cornet - C8
« on: 22 Jan 2004, 06:26 am »
Can I use .007uF Auricaps in this position?  The spec says .001uF and wondering if I need to stick with the exact spec value.
GRD
Cornet - C8
« Reply #1 on: 22 Jan 2004, 06:18 pm »
Better stick with the exact value for C8 as it is part of the RIAA filter.  Changing the value will change the equalization.  Multicap has a cap in that value if you are looking for an alternate.
For further reading if you are math inclined:
http://www.hagtech.com/equalization.html
hagtech
Cornet - C8
« Reply #2 on: 23 Jan 2004, 07:11 am »
Please don't stray from nominal values for the EQ.  This is all carefully balanced to yield accurate results.  Five or ten percent is fine, but not 700%!
jh :)
Grover
Cornet - C8
« Reply #3 on: 23 Jan 2004, 02:53 pm »
But Jim, it's 700% of such a SMALL number, sheesh!
OK, OK, thanks guys and I can take a hint.   :wink:
I'll use the Multicap RT .001uF Polystyrene and Tin Foil for C8.   I'm sourcing most of my parts from Michael Percy, but will probably need to go to about 4 suppliers to get everything I want.  Chassis is coming from Welborne Labs and the kit should be to me next week.
andrew
Cornet - C8
« Reply #4 on: 24 Jan 2004, 05:38 pm »
-- Jim,
Can you confirm that a 1nF Multicap would be OK at C8?
I'd just like to check with you since the parts list specifies a 630Volt cap here, but both logic and LTSpice says that a much lower value would be OK. I get about 130v in LTSpice.
Did you select the 630V cap for its availability at Mouser?
  many thanks,
